Change Fur Color on Lord of Snow Outfit?
I've tried and tried to figure it out. I select the fur color and the Fur Cloak Base and nothing happens. Do I need to select it before I do the "to Obj" in the LAMH window? I'm at a loss here. Any help would be appreciated.
  • NorthOf45NorthOf45 Posts: 5,896
    Hey, I just used it for the first time, myself (had it for months) and it took me a while to realise why it wouldn't set the materials. They use shaders, so you must go to the Surface tab for each and select the actual surface (FurBase in both cases) then apply the appropriate shader.
