Dson Poser companion File Creation Help needed
I have been doing what should be the easiest conversion/creation process, I have DS 4.6, and have been converting/ creating poser companion file, both are new enough to be .DUF files already, and most everything converted well, but here are my issues and hopefully someone can help me figure out to what to do.
First product is Future Wilderness by Luthbel, most of it did ok but while the knife and sheath and strap and elbow pads did not convert well my biggest problem is the quiver doesn't show up at all when I try to load it, the poser companion file created by DS 4.6 is a prop file, in DS it is a prop, but when I try to load it in Poser 9 it shows it listed in the figures drop down not the props drop down area and no item in work area,
The other is trying to use the Poser companion files for Vanandars Lord General, Almost everything seems to be loading ok except his boots, they are showing up in the figure drop down list, but no boots in the work area. so any help is greatly accepted,
I am sure there are those more experienced and knowledgeable than me who can point me in the right direction, I haven't even been brave enough to try to convert older DS formats a to DUF and go from there, one step at a time I want to be good at doing the conversion to Poser from DUF files before I try anything else.
Dimension3D has a DSON loader script for free here
http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
Nope, I tried using it to import the boots and quiver, no joy, tried the original .duf and the ones created by DS 4.6, nd even the .dsf too.
