wats best way please
fairyfantastic
hi all i made a jumpmer in hex saved and popped in daz rigged ect n exported obj back to hex so i can morph it with hoo
down now this is were im struggling i want it to look natrural but canget it right seem to get it right some how i
there any other way apart from bones which ive tried and struggled with
can i delete the hood and make a sep one and readd to juper thn pop in to daz to morph it
What figure is your jumper for?
Push the bone for hood as down as you can and import _this_ mesh into Hexagon.
In Hexagon, look into Surface and UV map instruments and try to use Smooth, Inflate and Pinch brush (they do some sculpting) to give your hood a more realistic morph.
No, if you delete the hood you won't be able to make it a morph to existing clothes.
its for genisis hun
You can delete the hood and make a new jumper using the old one as a rigging template for the new one. It is easier with Genesis because you don't have to bother with grouping much.
thnks for yr reply hun ill try wat u said and see if i can master it xx
