Weird pattern on Morphing Pantyhose
jsdaz_5811013940
I keep getting this weird pattern with Morphing Pantyhose. It is not in the bump or displacement maps. Suggestions?
Thanks,
Glisten
838 x 1031 - 158K
Normal map?
Thanks for writing back. Normal map is empty (choose map).
Found the problem. There is a bump map with tiny variations in the middle grey. It was not apparent when I first looked at the bump map. Even zoomed to 800% the differences were not apparent until i narrowed the exposure window dramatically. The grey difference was 104 to 103 out of 256. As subtle as they come. Surprising that such a tiny difference led to such deep appearing artifacts.
Thanks again,
Glisten
OK this makes more sense. The bump setting was 20. Went through the various materials. Most have the bump setting at 20. I tested this by setting it down to 1 and applying a new material. Most reset it to 20, way too high. Could my installation be messed up? Hmm.
