Measure Metrics: Create New Follower?
evilded777
Trying to measure something, and it seems the best way to do so would be to create two new followers and measure the different between the two. But I don't see how that might be done as there does not seem to be an option to create a follower.
Thoughts?
Post edited by evilded777 on
Never mind, I found the directions. I should have read more carefully.
Or not... as the directions do not seem to work, exactly. The Follower is not created at the point I selected the polygons, but floating off in space.
Manually moved the followers into place, but if this is accurate, Genesis 3 Male who stands at 5'7" has a shoe size of 7 with his toe to heel measurement being 10 inches (approx).
Either his feet are way too small for his size (should be between 9 and 11), or something is not right here.
Cleared up some of my glaring errors (don't have Symetry turned on, and don't have morphs applied), but the measurement is still roughly the same from heel to toe: 9.95 in, which is a size 7. I'm 5'7" and my feet are small at 8.5.
I take a (UK) 7 and I'm something like 5'8".
Which is a US 8 or so, a little small for your frame, but not overly.
https://www.onaverage.co.uk/body-averages/average-male-shoe-size
These are UK sizes I would assume. I don't know how trustworthy this data is, but in my own experience (I buy a lot of sneakers as gifts), these seem like pretty good numbers.
Elijah with a more realistic (for his height) size 12 shoe.
I imagine I can freely give away the foot measurement wearables I made for Genesis 2, 3 and 8?
Yes.
