Spawning D-Former doesn't create a morph
Hello!
I've created a D-Former on Genesis 2 Female which seemingly worked fine.
First I dialed in a morph on the head.
Then I created a new D-Former on Genesis 2 Female.
I've scaled the field so that it occupies the head, and I dragged the base into the head.
I've tested the D-Former by selecting Genesis 2 Female->D-Former_1_Base->D-Former-1, then going to Parameters->Transforms->Scale and dialing it up. The head became bigger, so it worked fine.
Now I want to spawn the D-Former.
Therefore I go to Windows->Tabs->D-Former.
I click "Genesis 2 Female" in the scene view.
I check the options "Create Root Control Parameter", "Delete Applied D-Former(s)" and "Apply Spawned Morph".
Then I click "Spawn Morph...".
DAZ tells me "The D-Former "D-Former_1" still affects some nodes. Do you want to delete it anyway?".
I select "Yes".
The D-Former is now gone, and I try to locate in in the Parameters tab. But it's nowhere to be found.
What am I doing wrong?
Thank you!
Hmmm, just when I posted it, it DID work while all the time it didn't. So strange.
The morph is to be found under "Parameters->Morphs".
I'll leave the posting here anyways in case somebody else every gets stuck.
I found the culprit.
All the time I tried it without changing anything in
I did that because I simply wanted to dial in a morph but not change the size or translation or rotation or anything.
It seems that if I don't change anything here, the morph is simply not created.
Good to know.
