ISO a hill with trees, low or high polly
StratDragonStratDragon Posts: 3,290
Anyone know where I can find a hill, a park or a ground cover and some trees, even if they are transparencies on a flat surface for a distance render in DS4.6? thanks!
  • JaderailJaderail Posts: 0
    Got any examples? I might have a few ideas if I knew more about what your looking for.
  • StratDragonStratDragon Posts: 3,290
    something in a city park, I can't think of a set or image that is what I'm looking for, It's still in the "Illl know it when I see it." department.
    thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,701
    There are two items, both with "lost" in the name, that spring to mind though both may be too small:
    http://www.daz3d.com/the-lost-garden
    http://www.daz3d.com/lost-cemetery
    thanks Richard, these are a little "stark" I'm looking for something something a little larger as well.
  • FirstBastionFirstBastion Posts: 8,076
    When you mention park, this one came to mind, but it's not a traditional environment but it is full 360.
    http://www.daz3d.com/urban-recreation
    the PA also has another one called monteray with more trees.
    How about the landforms from Boot Hill, Nerd's tropical cove set (not a hill, but it has slopes) or some of the Tropical Quest sets with the plants from Andrey Pestryakov's Forest sets (that last gets a bit complex as I think you need one of the big sets for textures, then the smaller set of props for the separate trees)
    edited May 2013
    Fober put out a free set called The Hills, which is completely compatible with his The Lake texturally (summer/winter) that was sold here at one point if you happen to have that.
    The Hills: http://www.sharecg.com/v/39996
    Post edited by Lissa_xyz on
    thats one is just crazy enough to work, thank you and thanks all of you for your help!
  • Dream CutterDream Cutter Posts: 1,224
    edited May 2013
    http://farmpeeps.com/farmpeeps_products.html
    Farm and country Terrain, skyboxes and trees. All freebie download.
    Post edited by Dream Cutter on
