morphs++ won't load / what am I doing wrong?
waltergwalterg Posts: 0
Hey everybody, here's hoping someone can shed some light on this...
http://imgur.com/a/8jSKp
I uploaded a series of screenshots to illustrate my problem.
Pic 1 - loaded a Genesis child to illustrate that morphs/posing/parameters ARE working fine there.
2 - loaded a V4.2... powerloader came up and I checked off base morphs / morphs++ / muscle morphs
3 - once it finished the only thing it came up with for morphs was MaleBody, MaleBody NoScale
4 - the top 8 morphs are marked new (I un/reinstalled them using DIM to see if that would fix it).. I'll show you what happens if I double-click them
5 - some of the worked, some of them didn't.
(they also didn't show up in the shaping or posing pane, in case I'm missing something there)
They had been working as intended yesterday and I have no (*@#$(*@#$ clue what brought this about...
If anyone can help me out I would be very thankful :((!!
  • JaderailJaderail Posts: 0
    edited May 2013
    EDITED : I miss read.
    The Morphs++ on a V4 figure only show in Parameters as they did in DS3. They are not coded to be included in Shaping and Posing like the Genesis morph sets are.
    Post edited by Jaderail on
  • waltergwalterg Posts: 0
    sorry sorry - I wasn't trying to use them on a genesis model...
    I was trying to illustrate that my V4/M4 morphs don't work on my V4/M4 models and specifics of THAT
    (but that my genesis morphs DO work for my genesis model... so it's not like... ENTIRELY screwed up or something??)
    edited May 2013
    I Edited my post, please see above.
    Edit again Are the morphs installed to the same Place V4 M4 are installed? They must be to work.
    Noted! Again, not too concerned about shaping or posing.. just figured I should have mentioned that in the first place in case it was a factor?
    Eurhm.... another thing.. in parameters, enabling Show Hidden Properties.. all the morphs do show up... but they have EMPTY- written before all of them.... otherwise function as intended though?
    That's a new one, At least they work. Did you just do a Reinstall? If so you might need to run the Bat setup file. That could be why the channels list as Empty. The Bat file should be in the Base folder the Figure is installed to. As Shown here.
    221 x 360 - 9K
    ran the bat files... still not working / showing up without hidden properties.
    For the record, I uninstalled and reinstalled with DIM - problem still existed
    (tried installing it to the non-default folder, and setting it up in content directory manager - problem still existed)
    I tried deleting all the content, redownloading and reinstalling with DIM - no change.
    tried uninstalling and reinstalling Daz3D, to see if that would reset any defaults/whatever - no change.
    I am actually embarrassed how badly I've got things screwed up here, no joke :-S... thank you very much for your help thus far.
  • Richard HaseltineRichard Haseltine Posts: 111,921
    Go to the Advanced tab of Power Loader - what options are checked there?
