Where do I enable the visual guide/frame for render dimensions in preview mode?
Nanstein
In previous versions of DS, when you go to Render Settings and change the dimensions for an image you're about to render to a custom setting, there used to be a helpful box or frame displayed in preview mode that shows you how much of your scene is going to show up in that render you're about to do. I really need that. Is it disabled by default? Where do I enable it? I have looked for this setting in Preferences, but all I found was the ability to tell DS to ignore your latest render settings when starting a new scene.
Thanks in advance :-)
Post edited by Nanstein on
It is in the drop-down menu for the Viewport, (a small lined square with a triangle), and it is called Show Aspect Frame, just tick that and it will display.
JimmyC, you made my day! :D Thank you ten hundred times.
My pleasure :-)
