Kiyomi, My new character. Any thoughts?
cj9831cj9831 Posts: 0
edited May 2013 in New Users
So i was just wondering how to set the daz 3d background from blue to black, so i can set up my lighting so it looks like she's in the dark when i render an image.
1832 x 882 - 476K
Post edited by cj9831 on
  • irelandmichaelirelandmichael Posts: 0
    Im a Daz newbie but I think I can help. When you are looking at your render, there is a little icon on top right hand corner, "Display Viewport Options" it has a drop down menu that allows you to change background color. The Icon is 4 small horizontal lines. Hope this helps. If you want to change background image, use Edit>Backdrop and you can browse to a background image you like to use.
  • NovicaNovica Posts: 23,925
    You helped precisely right. Way to go! :) And welcome to the forums.
    Cathie
  • cj9831cj9831 Posts: 0
    Thanks irelandmichael, Not sure why i never looked there before. It just helps when setting up lighting
    edited May 2013
    Ok, so this is what im going for, any tips on lighting is welcome. Just wish i could turn the headlights on!! lol
    1832 x 882 - 186K
  • pwiecekpwiecek Posts: 1,598
    edited May 2013
    What you're looking for is called ambient lighting. If you want actual beams it's called volumetric lighting. I don't use DS so I can't give directions, but you can do a search for those terms.
    Post edited by pwiecek on
    Thanks, i'll look for that!
  • SiscaSisca Posts: 875
    A good tutorial on lighting using the UberEnvironment lights from AdamR - http://www.daz3d.com/forums/discussion/5320/
    I also highly recommend following Novica's thread - the Art Studio link in her sig above - there's a ton of useful information for us newbies gathered there.
    Why thank you Sisca! :) Glad folks are using it. And feel free to post over there if you find a good tutorial or link with useful information- I'm trying to get it all in one spot, but when I'm busy with the video tutorials, I don't get to surf the forums and things get buried.
    I'm sure the lighting pros will come along and tell you how, I did see a video from daz on YouTube about lighting a torch- it would be the same thing. Maybe a linear point light?
  • frank0314frank0314 Posts: 15,098
    edited May 2013
    What kind of feel are you going for with the scene. Daytime, evening, night etc.. Light can be hard to get down right so you need a basic mood you are wanting to get across to users
    Post edited by frank0314 on
    edited May 2013
    Okay, let me post the photo then I'll edit with the explanation.
    EDIT: Don't you laugh at my toon car! Not as sleek as your vehicle, but I love it anyway.
    So, I used a point light. First photo on left: Go to TOP VIEW to place lights such as sirens, it really helps.
    Then perspective view (second photo, on right.)
    Bottom left: this is what it looks like before rendering. I went in to Parameters/Light and made the light blue, intensity 150%
    (When choosing headlights- don't go with just white, have a bluish white IMO)
    Bottom right: ta dah, siren glows.
    This should work with headlights, at least to get them lit. Might try a linear point light to get beams. you can also raise this light so the glow is off the vehicle and more in the air. I just did it quickly without adjustments. Again, a pro needs to jump in and help. :)
    EDIT: I see you have one! Also, for brand new folks, to create a new light, go to top left and choose "Create>New (Whatever)"
    Cathie
    1696 x 1570 - 189K
    Post edited by Novica on
    Ok, again I am by far a Daz guru or anything remotely close. I just wanted to share with you my experience. I found that I learned so much about lighting by just boiling a kettle, making tea and sitting down at me PC and I rezzed a sphere and placed in on top of a plane. Go to the Surface/Rendering tab and play around with the different settings for the surfaces of each object, render it and see what does what. I found that a simple plane with Diffuse color set to black and Reflection color set to White, Reflection Strength set to 100% will produce a reflection of an object that is near it, alot like a glossy black marble floor would. A spotlight of some kind of overhead lighting is required as well to create the reflection. Like I say, just play around with simple objects and you will learn so much along your journey. Cheers!
    That doesn't create a BEAM of light does it? Coming from the headlights? It's not ambient light that's needed (if I am using the right term, meaning an all around glow without a specific source strongly identified) Getting that glow sounds neat, but the headlights would be shining forward- I tried a spotlight placed inside the headlight, pointing out. No beam of light when spot rendered. I couldn't find the torch thing on YouTube either, I've been looking. But even that doesn't produce beams, they pretty much did what I did with the point light. (siren) If you only want the headlights to glow, go that route. If you want beams, I haven't been successful testing a spotlight. Gotta run work on some other things but I'll be interested to see how this is solved. (And add it to my studio thread so others can find it.) :)
    edited May 2013
    http://www.daz3d.com/atmospheric-effects-cameras-for-daz-studio
    Found in a forum post from May, for beams of light this will work. (Don't ask me.) But when I googled, that is what came up.
    thread: http://www.daz3d.com/forums/discussion/627/
    EDIT: Here is the help tutorial. REALLY neat. Put it on your wishlists! :)
    http://www.ageofarmour.com/3d/tutorials/AoA_atmospheric_cameras_help.html
  • JaderailJaderail Posts: 0
    Only Volumetric shaders such as Uber Volume can cause that effect, or a Camera built in Shader Maker, Or bought. Basic lights of any type can not produce the Beam effect in a Daz Studio Render.
    edited May 2013
    All good thoughts, im going to try and see what each does, and Frank0314 im kinda going for night time , dark mood, only a little light to reflect off car onto Kiyomi. But that could change later on. Thanks all of you for The ideas, gives me alot to try and play with.
    Like the atmospheric one I posted? I have that product and am downloading it now to play with it. :)
    BTW, love your new avatar's look Jaderail! WOOT!
    Yes that should do it, I use that camera set myself. And Thank you, the Avy is to honor those that invited me into the BWC.
