Need help restoring closed tabs
Hi!
I'm having a difficulty restoring closed tabs on the right side - like Parameters, Shaping, etc. How can I get those back?
Thanks!
Mortir
    Menu item Window>Panes(Tabs) will open the selected tab. you may have to redock them.
    If you have saved your layout, or are using one of the standard choices you can just reopen the layout Window>Workspace>Select Layout
  • Thank  you so much! I appreciate it!
    Best,
    Mortir
