Did "scale" disappear from DAZ 4.6
TomViolaTomViola Posts: 103
Unless I am mistaken, I cannot find the "scale" option in DAZ 4.6. Can anyone direct me?
  • Richard HaseltineRichard Haseltine Posts: 111,688
    On what? I'm still seeing it where I expect to.
  • srieschsriesch Posts: 4,243
    I have a scene right now in DAZ Studio 4.5.1.56 where I have the Cap2.cr2 from the Daedalus Sky Mercenary, which doesn't show any Scale slider in the Parameters tab, nor the little cube-shaped scale handle in the universal tool. Other things in the scene have it. However when I loaded the object in DAZ Studio 4.6, I DO see the scale parameter. I'm not sure why that is.
  • fixmypcmikefixmypcmike Posts: 19,729
    Is it Fit to the figure on both machines (or is it 32 and 64 bit on the same machine)? Do both machines have "Show hidden parameters" on?
    @Fixmypcmike, that was it for me. In 4.5.1.56, fitting the cap to M3 made the scale parameter disappear, and selecting "show hidden properties" from the Parameter Pane's menu made it reappear again.
    However, in 4.6, the scale is always shown, regardless of whether I have selected "Show Hidden Properties" (slightly different menu option name in this version) checked or not; maybe I'm not seeing exactly the same thing @TomViola was seeing after all.
    @TomViola, do fixmypcmike's steps solve it for you in 4.6?
  • davidbrucesmithdavidbrucesmith Posts: 9
    If you want to hide the scale then you can set it in the parameters button and then select "Hidden"
    314 x 167 - 24K
