Fireflies (I think)?
A while back I did a render and the hair in the scene had blue and red bright pixels appear. I've had this issue before and solved it by reducing the reflection texture setting of the hair to zero. But this time the problem continued. So I went through all the settings,one by one setting them to zero and rendering as I went. Eventually every setting was zero apart from diffuse strength and still the pixels appeared. What could cause this and how do I stop it?
Cheers.
  • LeanaLeana Posts: 13,490
    edited January 2018
    In 3Delight you can get those when using "Shadow Map" option on the lights. Sometimes moving the camera a bit can solve it, but the best way to avoid it is to switch to raytraced shadows.
    Post edited by Leana on
  • SteveM17SteveM17 Posts: 1,061
    Raytraced shadows did get rid of the pixels, sadly it took a fair bit longer than shadow mapping. Sometimes you just can't win I suppose!
