Problem with shaders
EddyMI3D
Hi there,
I just purchased magaremoto's 'Props for Landscape Scenes: 15 Shaders for Exteriors'.(http://www.daz3d.com/props-for-landscape-scenes-15-shaders-for-exteriors)
So there are several scenes but no shaders in the set.
Someone any Idea?
Eddy
Did the installer not put the shader files into your Browser? One possible way to test is to run the installer but point it to an empty folder.
If you are using a PC, you can also run SysInternals' free utility Process Monitor while the installer runs. It has daunting output, but it will show you every file and Registry key that a process (i.e. the installer) touches while it runs.
hello,
you should find the textures in Presets/Textures folder, anyway I have sent to you a mail with a link for the zip to be downloaded.
enjoy
Hi magaremoto,
found them. Thanks a lot!
Eddy
