Move My Daz 3D Library folder to Studio folder
I am trying to tidy up my folders a bit. In My Documents folder is the Daz 3D folder with the Daz programs I own listed inside. At the bottom of the list of folders is the Studio folder. Today I found the folder with all my content outside the Studio folder in a folder named My Daz 3d Library. I would like to move this folder into the Studio folder. Is it ok to move this folder or will everything break? Thank you for any help.
  • I think you can edit the Preferences to change what goes into this folder, or replace it with another one. Not sure as I don't let it put anything on C:\ drive in the first place.
  • SamanthieSamanthie Posts: 308
    edited January 2018
     Thank you good to know but still would like to move the folder if possible.
    Post edited by Samanthie on
  • As long as the program no longer points to this folder, you can safely move the contents anywhere you like.
    edited January 2018
    Oh I think I see now. So if I edit it in preferences in studio (like remove it from the content directory list) then I can move the folder? Thank you DrNewcenstein :)
    You also need to modify the Download and Install paths in DIM (if you use it).
    Will do, thank you fastbike1.
