Luxus not present in my list of RENDER engines.
I just purchased Luxus, and I am excited about putting it to work.
However, according to the online documentation: http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/15891/15891_luxus-manual.pdf
I should be able to find the option of "LuxRender via Luxus" in the Render Engine section, but it's not there. Any clue as to what I can do?
I am using Windows 64, Daz Studio 4.6, and I have installed the appropriate version of LuxRender.
Thanks in advance for your help!
Post edited by Yamaneko on
Where did you look? It should be, if installed properly, in a drop-down box that says "3delight" by default. Otherwise, it's possible that the plug-in is not registered properly. Check in Help:About Installed Plugins. Maybe just needs your registration number, I can't remember from when I installed.
Thanks for taking the time to help out.
The drop-down menu with 3D Delight is exactly where I looked, but it wasn't there.
The other Luxus stuff- shaders and light settings- are in my content library, so somethings got installed.
I will check out the Help with Installed Plugins that you recommended.
Thanks agian.
I just ran the exe file from my product library.
Now it's there. I guess I just got used to the Daz installer doing all that!
Cheers
Did you point Luxus to the Luxrender Exe first in the Render Setting at the very top of the Lux settings in Daz Studio.
