Merging two objects into one (cannot find the clear answer)
in The Commons
Just like G8 female with her eyeslashes. How to create that two object into one figure and not export as obj..
my proops a piece cloth with button..
I'm not a modeler and I don't know the answer to your question as asked.
However, it is possible to use Rigid Follow Nodes to attach one object to another. I have several outfits where the PA(s) used this method to attach buttons to shirts. The advantage is the buttons do not distort when the clothing is fit to a figure or pose. Instead, the button simply moves. You'll need to use the Geometry Editor to select the face of a polygon where you want to place the button, Create a Rigid Follow Node for Selected, Now move the button into place on the cloth, and then parent the button to the Rigid Follow Node. Repeat for each button.
I don't know if this will help you, but I thought I'd "put it out there" just in case.
