V4 Male UV maps for Genesis 3/8 Male
Noah LGPNoah LGP Posts: 2,617
edited January 2018 in Product Suggestions
Hi,
There are some Victoria 4 male textures I would like to use on Genesis 3/8 Male figures.
Post edited by Noah LGP on
  • vwranglervwrangler Posts: 5,045
    Well, this exists: https://www.daz3d.com/legacy-uvs-for-genesis-8-victoria-4
    However, V4 for G3M would be a really niche market with fairly little interest, so it may not be profitable enough to develop for G3M.
    The other alternative is to get something like Texture Transformer 2 from Renderosity to rewrite the maps. There's also a method somewhere in the forum for using Blender and other free tools to do it, which requires far more knowledge of things than I posess.
  • Noah LGPNoah LGP Posts: 2,617
    edited January 2018
    @vwrangler
    But V4 for only Genesis 8 female, I already own this product.
    I don't mean to do it alone but it would be nice if a product could include this feature.
    About Texture Transformer 2, Victoria 4.2 to Genesis 2/3 Female it seems to be impossible to convert to male.
    Is a texture converter able to convert V4 male Anatomical Elements (M3 genital) ?
  • RedzRedz Posts: 1,459
    There is also a V4 for Genesis 3 Female
    https://www.renderosity.com/mod/bcs/legacy-uvs-for-genesis-3-v4/113767/
    Alternatively , if you transfer the maps to the base female UV then you could use a UV swap product to have G3M wear the female skin
    https://www.daz3d.com/genesis-3-uv-swap-male-and-female-base
    https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base
  • LeanaLeana Posts: 13,502
    edited January 2018
    You could use Genesis 1 and Map transfer to convert the textures from V4 UVs to M4 UVs, then use the M4 legacy UVs for G3M or G8M. That won't help for the genitals though.
    Post edited by Leana on
    edited January 2018
    You'll probably have to do some hunting for the freebie, but here is the thread, but this person did a remap of the Genesis 1 genitals to accept the M3 gens. You would need to try to map transfer that to the genesis base and try to apply that to whatever solution you will use. It will require some photoshopping work to clean it up, but i did manage to get Jinn and the gens textures useable on Genesis 2 after using map transfer to the M4 UV.
    If you can't find the files, your only solution would be to use the M3 gens and parent them or find one of the freebie gens floating around that can take M3 textures.
    Post edited by Male-M3dia on
    edited January 2018
    @vwrangler @Redz @Leana @"Male-M3dia" Okay, thank you for your help.
    I think I will use a M4 conversion without the anatomy elements.
    @Leana you made me discover the Map Transfer, thank you very much !
    I believe once you have V4 textures transferred to G3F & G8F then you could use Slosh's UV Swapper for G3 & G8 if your attempt to create a direct texture mapping to the G3M / G8M model UVs.
    edited January 2018
    @nonesuch00 Sure it can be another way. Thank you.
    • V4 -> M4 -> Legacy UV
    • V4 -> G3F -> UV Swapper
