Stand Up Poses for V5 - installed but not showing in Daz Studio 4.5
adamkpadamkp Posts: 0
edited May 2013 in New Users
Hi there. I just bought and installed Stand Up Poses for V5. I have V5 installed via the Daz 3d Install Manager. I also installed Stand Up Poses for V5 using the Daz 3d Install manager as well.
When I add a model to my scene and then look at the available poses I do not see anything new. When I use the "products" tab in the content selection I do not see Stand Up Poses for V5 installed. Is there something else I need to do?
I did try to do a "Content Database Maintenance" and "Process Metadata Queue" and "Re-Import Metadata"
Those did not seem to help.
Thanks for any help you can offer.
Post edited by adamkp on
  • JaderailJaderail Posts: 0
    Do you have the Figure SELECTED in the Scene Tab before you open Smart content? If so are you looking in Files as well as Products with the Figure selected? It must be Genesis selected and not any other item. Smart only shows items that can be used with the selected item.
  • adamkpadamkp Posts: 0
    I just upgraded to 4.6 and it didn't seem to help. Here is my process:
    1) Open Daz studio and close the "Start Learning Now!" window
    2) In the "Actors, Wardrobe & Props" panel I select figures.
    3) I add V5 to the scene by double clicking on the Actor icon named "Victoria 5"
    4) The moment the figure is added I see the following: "Genesis" is selected as the type in the Smart Content panel and "Genesis" is selected in the Scene panel on the right
    5) I open the "Poses" section and select "By Function"
    6) I scan through all the available poses and see none of the new ones from the pack.
    7) I switch from "Files" to "Products" and reselect poses.
    8) I see "Genesis Starter Essentials" "M5 Base Poses", "Mega Mood Expressions", Night Guard For Genesis Male", "Victoria 5"
    9 No "Stand Up Poses for V5" product
    10) Next I try to switch the smart dropdown to "Victoria 5" Many of the products are filtered out but some remain (like "Mega Mood Expressions")
    11) I still see no "Stand Up Poses for V5" product
    Did I so something wrong in that list? Did I install it wrong?
  • R25SR25S Posts: 595
    You say you open the Poses Section... it's not clear if you did you select the path My DAZ 3D Library/People/Genesis/Poses/Stand Up Poses V5? (it should be there)
    or My DAZ 3D Library/Poses?
    R25S: I was trying to use the Smart Content Panel. I found I can use the "Content Library" panel on the right to use these new poses. But I am still not seeing them in the "Smart Content" panel on the left. When I see the check box next to "Smart" in the Daz Install Manager I thought that meant I'd see it in the "Smart Content" panels. Is this incorrect?
    I see... you use the categories...
    try using the other path.
    I didn't use the categories because many things didn't show up there.
    1366 x 768 - 97K
  • LindseyLindsey Posts: 2,017
    Have you tried to re-import the metadata? If it's successful, you'll see it in appear in Content Library>Products and the Smart Content tab.
