Shadow Map time
For some reason my last few renders have taken a lot longer to create shadow maps than they used to. I render in 3Delight. I thought it might be to do with the textures I was using as some of them may be for Iray without me knowing, so I set up some lights in an empty scene, and the shadow maps still took ages to create before rendering even though there's nothing to cast any shadows. I haven't made any drastic alterations as far as I'm aware. My shadow maps used to be much quicker than this! Any ideas?
    edited January 2018
    I haven't used shadow maps for a long time so no idea why, you might want to consider starting to use raytraced shadows as they render a lot faster nowadays than shadowmaps.
    ETA: What version of DS are you using?
    Post edited by Sven Dullah on
  • SteveM17SteveM17 Posts: 1,060
    I'm using 4.8 pro. I tend to avoid updating things because the latest versions of software always changes/removes a feature I don't want it to. Thanks for your advice, I'll give raytracing a try, not used it for ages (I always thought it took longer, but maybe that depends on the complexity of the scene?). Cheers.
    Yep, I think you'll be pleseantly surprised;) And note that shadow bias have to be decreased when using raytraced shadows. I usually start with 0.1 and go from there.
    Just tried a quick one person/one raytraced spotlight render and it was quicker. Will continue to experiment, thanks.
    No prob;) Happy rendering=)
