Setting UVs on a material
I was wondering... is there a way to set UVs on a material by its name? Setting it by its index works:
var baseUV=myMaterial.findPropertyByLabel("UV Set")
                baseUV.setValue(2);
But on different figures, the UV map matching such index may not be the same...
  • meipemeipe Posts: 108
    Thanks a lot! :)
    So, the solution is:
    1-Get the name of source UV set:
    var myUVName = oSrcMaterial.getUVSetControl().getStringValue();
    2-Iterate in the destination UV set, getting one by one the UV sets names, checking for a match and grabbing its index number;
    3- if there is a match, setting the destination UV set:
    var tgtUV=oTgtMaterial.findPropertyByLabel("UV Set")tgtUV.setValue(myIndexNumber);
