Problems with Genesis figure after loading a saved scene
in New Users
Hi!
I'm having an issue with a Genesis figure after loading a saved scene - it's turned to an oddly-shaped mess. The other figures in the scene are fine. I've tried turning the visibility of the Genesis figure off and back on with no luck, closing the program and reloading with no luck, and even rebooting the computer and reloading with no luck. No sure at all what's happened. I'm attaching a file of a screenshot of the workspace, and one of the picture rendering (the Genesis figure has vanished completely, but the rest of the scene and props are visible. Visibility in Render is turned on.
Thanks!
1680 x 1050 - 427K
1680 x 1050 - 380K
The geometry is not being found - do you not get a missing file error when opening the scene?
No missing file errors, and I can load the figure again manually, but if I save it, exit, and try to reopen it, the same thing happens.
Please open the scene, then go to Help>Troubleshooting>View Log, scroll to the very end, then select the last page or so of entries above that and post them here.
[snipped]
2018-01-04 09:45:29.458 *** Scene Cleared ***
2018-01-04 09:45:31.052 WARNING: fileinput\dzassetdaz.cpp(1904): Could not find geometry definition: /data/DAZ%203D/Genesis/Base/Genesis.dsf#geometry.
2018-01-04 09:45:31.067 WARNING: fileinput\dzassetdaz.cpp(1349): Failed to create uv set!
2018-01-04 09:45:31.099 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
2018-01-04 09:45:31.099 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2018-01-04 09:45:31.114 WARNING: fileinput\dzassetdaz.cpp(1368): Failed to create material!
2018-01-04 09:45:31.114 WARNING: fileinput\dzassetdaz.cpp(4817): Could not find geometry for the material instance.m_uri.
[snip]
2018-01-04 09:45:31.224 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMV4HdEyesClosedR.
2018-01-04 09:45:31.224 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMV4HdEyesClosedR!
2018-01-04 09:45:31.224 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMV4HdEyesClosedL.
2018-01-04 09:45:31.224 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMV4HdEyesClosedL!
2018-01-04 09:45:31.224 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMV4EyesClosedR.
2018-01-04 09:45:31.239 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMV4EyesClosedR!
2018-01-04 09:45:31.239 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMV4EyesClosedL.
2018-01-04 09:45:31.239 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMV4EyesClosedL!
2018-01-04 09:45:31.239 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FHMVictoria4.
2018-01-04 09:45:31.239 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FHMVictoria4!
[snip]
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMThighsVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMThighsVolume!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMShouldersVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMShouldersVolume!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMShinsVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMShinsVolume!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMRibcageVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMRibcageVolume!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMNeckSize.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMNeckSize!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMNavel.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMNavel!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMLatsVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMLatsVolume!
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMKneeBonesVolume.
2018-01-04 09:45:31.489 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMKneeBonesVolume!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMHipVolume.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMHipVolume!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMHipBoneVolume.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMHipBoneVolume!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMHandsThick.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMHandsThick!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMGlutesVolume.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMGlutesVolume!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMForearmsVolume.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMForearmsVolume!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: PBMFeetThick.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: PBMFeetThick!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMChildEyesClosedR.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMChildEyesClosedR!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: MCMChildEyesClosedL.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: MCMChildEyesClosedL!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: JCMrFingersClosed.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: JCMrFingersClosed!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: JCMlFingersClosed.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: JCMlFingersClosed!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FHMBasicMale.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FHMBasicMale!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FHMBasicFemale.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FHMBasicFemale!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FHMAlienHumanoid.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FHMAlienHumanoid!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMThin.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMThin!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMPotBellied.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMPotBellied!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMPearFigure.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMPearFigure!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMHeavy.
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMHeavy!
2018-01-04 09:45:31.505 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMBodyVolume.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMBodyVolume!
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMBodybuilder.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMBodybuilder!
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMBasicMale.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMBasicMale!
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMBasicFemale.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMBasicFemale!
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: FBMBasicChild.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: FBMBasicChild!
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: CloneVictoria4.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: CloneVictoria4!
[snip]
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(4908): Could not find parent for modifier: CloneAiko4.
2018-01-04 09:45:31.521 WARNING: fileinput\dzassetdaz.cpp(1427): Failed to prepare modifier: CloneAiko4!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMV4HdEyesClosedR!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMV4HdEyesClosedL!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMV4EyesClosedR!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMV4EyesClosedL!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: FHMVictoria4!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMM4HdEyesClosedR!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMM4HdEyesClosedL!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMM4EyesClosedR!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: MCMM4EyesClosedL!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: FHMMichael4!
2018-01-04 09:45:31.536 WARNING: fileinput\dzassetdaz.cpp(1438): Failed to create modifier: FBMMichael4!
[snip]
2018-01-04 09:45:31.927 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rFoot/bulge_weights/x/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.927 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/neck/bulge_weights/x/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.927 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/neck/bulge_weights/x/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rCollar/bulge_weights/z/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rCollar/bulge_weights/z/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rCollar/bulge_weights/z/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rCollar/bulge_weights/z/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lCollar/bulge_weights/z/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lCollar/bulge_weights/z/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lCollar/bulge_weights/z/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lCollar/bulge_weights/z/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rPectoral/bulge_weights/y/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lPectoral/bulge_weights/y/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lShin/bulge_weights/x/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rShin/bulge_weights/x/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/chest/bulge_weights/z/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.942 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/chest/bulge_weights/z/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/x/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/x/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/x/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/x/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/z/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/z/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/lThigh/bulge_weights/z/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/x/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/x/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/x/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/x/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/z/positive-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/z/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/rThigh/bulge_weights/z/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/abdomen2/bulge_weights/x/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.958 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/abdomen2/bulge_weights/x/negative-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.974 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/abdomen/bulge_weights/z/positive-right in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.974 WARNING: fileinput\dzassetdaz.cpp(5737): Could not find output property for formula: Genesis:/data/DAZ%203D/Genesis/Base/Genesis.dsf#SkinBinding?joints/abdomen/bulge_weights/z/negative-left in file : /data/DAZ%203D/Genesis/Base/Morphs/DAZ%203D/Victoria%204/FBMVictoria4.dsf#FBMVictoria4
2018-01-04 09:45:31.974 WARNING: fileinput\dzassetdaz.cpp(7190): Could not find geometry for applying UV Set!
2018-01-04 09:45:31.989 WARNING: fileinput\dzassetdaz.cpp(7190): Could not find geometry for applying UV Set!
2018-01-04 09:45:32.005 File loaded in 0 min 6.2 sec.
2018-01-04 09:45:32.005 Loaded file: Gazebo Caitlyn handles off.duf
Using Caitlyn for V4 and Genesis as Actor
Well, the first line after Scene Cleared - "2018-01-04 09:45:31.052 WARNING: fileinput\dzassetdaz.cpp(1904): Could not find geometry definition: /data/DAZ%203D/Genesis/Base/Genesis.dsf#geometry." - shows the issue, though it doesn't explain why you are not getting an alert. Do you in fact have a /data/DAZ 3D/Genesis/Base/Genesis.dsf file on your system, and if so where is it?
Yes, I do have the Genesis.dsf file on my system. It is in \DAZ 3D\Studio\My DAZ 3D Library\data\DAZ 3D\Genesis\Base\ with the rest of my content library. That library is on my D: drive - is it possible that for some reason it is looking for it on my C: drive? Again, everything else works fine, so I don't know why that single file is off. And again, it works fine loading things in the first time, it is only when I try to load the saved scenes that it screws up.
Thank you so much for looking into this for me! I do very much appreciate it!
Try uninstalling and reinstalling the Genesis Starter Essentials.
Done - no changes, the problem persists.
Is it possible you installed with Connect rather than DIM at some point?
Connect? I don't think so - I've installed everything with the DAZ Install Manager except the original Studio, which was installed with the program installer after the download. All the content has been installed with the DIM.
I'm not sure what else it could be. You could try finding Genesis Starter Essentials in the products tab of Smart Content, right-clicking, and - if the option is there - selecting Uninstall.
It wasn't there - I selected the All tab in All products and then chose the Install option - once Genesis Starter Essentials installed, I loaded the saved scene again and got a Duplicate error warning, clicked OK, and the scene loaded with the geometry showing correctly. May try uninstalling it with the DIM, and if required, reinstalling it using that option in Studio and see if that corrects the duplicate error when loading the scene. Will let you know if that fixes it tomorrow. Thanks for all your help and suggestions! They are most appreciated!
With the Connect install the DIM install will, or should be, ignoed (and other morphs installed with DIM wills till load, however). If you were getting a Duplicate Formula error that's usually an issue with a product, or a cofnlict between two products, not something in the base.
Ok, well, it seems to have worked. Thanks again for all your help! It is much appreciated!
