mcjHoldOn - 2018 Update - animation helper : hand/foot orientation stabilizer
mCasualmCasual Posts: 4,607
edited January 2018 in Freebies
that's my old 2012 script which i ( and others!) still use to this day
https://sites.google.com/site/mcasualsdazscripts2/mcjholdo
example: you select a door handle, then select the hand of a figure holding that handle
you animate your figure moving around, maybe pulling on the handle
now your figure's hand is not holding the handle at all during the animation ! except for the first frame
so you use my other script mcjAutoLimb to keep the hand (wrist) location fixed for the duration of the animation
then you use mcjJoldOn to keep the hand orientation fixed, relatively to the handle
New in 2018
You can now type in the desired range
There's a web-Help button that will sent your browser to the release page
Settings are saved on exit
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited January 2018
    can also be used for the very tricky bike pedaling animations
    https://sites.google.com/site/mcasualsdazscripts5/tutorial-pedaling-with-mcjautolimb2014
    Post edited by Chohole on
  • CGI3DMCGI3DM Posts: 281
    Thanks, Great Tool.
  • Very nice all of your scripts are gold. Thank you
  • I agree, this add-on is pretty solid, but I wonder if it keeps the hands in sync with a wide knee-length (flared) skirt?
    I think it would also be a good idea to update the add-on to allow the legs to cling onto the inside of a slimmer skirt too.
    edited January 2018
    it's probably not evident but one could use my mcjApplique script
    https://sites.google.com/site/mcasualsdazscripts7/mcjapplique
    to get a null node to follow the skirt-edge location
    then mcjAutolimb to make the arm pose keep the hand to follow the skirt-edge node
    and mcjHoldOn would take care of the hand orientation
    here the 6 big buttons on the shorts are animated to stay on the shorts using mcjApplique
    ( because the way figure works the buttons would be stretched and squeezed if they were part of the shorts figure )
    note that Amy Ombrey's hands are kept at their positions and orientations *relative to the hip* using mcjAutoLimb and mcjHoldOn
  • v1si0n4ryv1si0n4ry Posts: 82
    Thank you SO MUCH
