Problem with wire bounding box
I'm having an issue where the model, for some reason, when I try moving the camera around or try manipulating anything within the viewport everything switches over to the Wire Bounding Box setting, then back to normal once I'm done manipulating it. I read on a discussion on someone's similar problem and their solution and it just doesnt work (the one where you go to the Tool Settings pane and change the During Manipulating setting to something else)
Is there any way I can get a resolution with this?
Go to the Draw Settings pane (Wndow>PAnes(Tabs)>Draw Settings if it isn't showing) and set the Manipulation Draw Style option to Use Current (Off)
Ohhhh, I see my problem. I was looking in the Tool Settings tab instead of the Draw Settings tab.
Thank you very much for helping me with this issue. :)
