Clearing out my wish-list -- is that possible with the new store software?
MorpheonMorpheon Posts: 738
I remember that the old store software had a function that allowed us to blank out our wish-lists, but I can't seem to find a similar function with the new store. Is this still an option, and if so, how do I access it? Thanks...
  • ShaneWSmithShaneWSmith Posts: 636
    Change the qty of each item to 0 and hit "update wishlist" - that's the fastest way I know of.
  • Dream CutterDream Cutter Posts: 1,224
    The easiest way is to buy em all ! :P
  • MorpheonMorpheon Posts: 738
    I'm doing that right now, and since I have almost 4,000 items in my list, it's gonna take a while...
    DAZ's wish-list didn't used to function that way (although Renderosity's does), and I don't know if they've added that functionality since the store change-over. Doesn't matter: I could never afford to use your suggestion, but thanks, anyways...
  • KatteyKattey Posts: 2,899
    Try right clicking on delete button in batches of 10 then closing the new tabs.
    edited May 2013
    Greetings,
    In your browser, there's a address bar up at the top. Right now it probably reads something like:
    http://www.daz3d.com/forums/discussion/22176/
    When you're looking at your Wishlist, move your cursor to the address bar, and delete everything there. Type the word javascript and then a ':' character, then:
    jQuery('input.qty').each(function(idx, elem) { elem.value = 0})
    (You can copy this, and paste it after "javascript:".)
    It should end up looking like this:
    javascript:jQuery('input.qty').each(function(idx, elem) { elem.value = 0})
    (You cannot copy and paste from that; the forum replaces single-quotes with 'smart quotes', which are not usable in JavaScript.)
    Hit enter with that in your address bar. That'll set all quantities in your wishlist to zero. You can then click the 'update wishlist' button and it should be empty afterwards.
    -- Morgan
    Post edited by CypherFOX on
    edited May 2013
    Cypherfox said:
    Greetings,
    -- Morgan
    THIS IS HANDY and easier on the wallet - MAYBE make message STICKY
    Post edited by Dream Cutter on
    edited May 2013
    Cypherfox said:
    Greetings,
    -- Morgan
    Thank you very much for this, but I'm not able to get it to work for some reason. I'm running Win7 64-bit with the latest version of FireFox (with AdBlock and NoScript installed).
    The first time I tried your suggestion (pasting "[removed]jQuery(‘input.qty’).each(function(idx, elem) { elem.value = 0})" -- without the qoutes -- in the address bar), FireFox threw up this error message:
    "[removed] and data: URIs typed or pasted in the address bar are disabled to prevent social engineering attacks.
    Developers can enable them for testing purposes by toggling the "noscript.allowURLBarJS" preference."
    Supposedly, by going to the address bar and typing in "about:config" (without the quotes) and after promising to be careful, you can search through FirFox's preferences to find "noscript.allowURLBarJS" and set it to TRUE -- unfortunately, "noscript.allowURLBarJS" doesn't appear amongst the eight or nine noScript preferences listed, so setting it to TRUE apparently isn't an option.
    Is this an entry I can create myself, or have I done something wrong? And interestingly, now I don't get the error message anymore (but it still doesn't set all the quantities to zero). Thanks...
    BTW, I see what you mean: the forum REALLY doesn't seem to like j_a_v_a_s_c_r_i_p_t_:
    Post edited by Morpheon on
    Holey moles! :ohh:
    Holey moles! :ohh:
    Hey, I'm already down to around 3,700+! Yeah, this isn't taking forever (sarc)...
  • Miss BMiss B Posts: 3,071
    It's unfortunate the store doesn't have a "select all" option. That would certainly make this a lot easier for you.
    Even selecting more than one product and sending them all to the cart at one time is something I've always liked, but an option DAZ has never had on either iteration of their stores.
  • TaozTaoz Posts: 10,313
    Holey moles! :ohh:
    I can write small utility that can do it, I'm planning on writing something to manage the wishlist so I'll have to write the code anyway.
    I'm just so tired of DAZ telling us how great the new store software is, and then finding out again and again all the things it CAN'T do compared to the old store software. The old store wish-list had a "clear all" or "delete all" function -- is DAZ simply dragging their feet putting that back in, or have they decided to skip it, or is the new store incapable of implementing it?
    The wishlist will be improved to make it easier to manage but it has low priority as there are more important things that needs to be solved first. Probably 3 months at least before they start on it as far as I've been told.
    edited May 2013
    Thanks for that. I was thinking it was a simple thing to implement but also something of a low priority -- but then again, I've been surprised by the things DAZ claims the new store CAN'T handle, so I wasn't about to rule out THAT scenario, either. Hey, DAZ, if you're listening, how about having purchased items automatically deleted from our wish-lists (the way Renderosity's wish-list handles it) so we don't have to hunt them down and remove them manually. Later....
