Create Deformer set that applies to any clothes
3dOutlaw3dOutlaw Posts: 2,481
If I create 4-6 deformers for a shirt, and then I want to save them off and apply them to another shirt, (i.e make them a library item, or freebie for others use, etc)...is it possible to do that?
    Deformer as in morph, or deformer as in D-Former?
    If the latter: http://wiki.daz3d.com/doku.php/artzone/pub/software/dazstudio/reference/fm_savedform
    If the former: No, but you can transfer them by conforming another item to the one that is morphed.
    I mean, save deformers like a magnet set (like Lyrra sells magnet sets for different body type fits, you jut buy them and then load them from the library against the selected object, and then you can move/adjust the magnets, after loading the set)
    I'll try that save as D-From Preset and see if it works, thanks.
    Necro-post, but I am doing the same thing again, and all my forum searches turned this up. :)
    So I made a character D-Former (not on Genesis, but on A3), using DS4.61P. I can make this pose preset mentioned above with no issue. I can also spawn a morph using the D-Form tab.
    Is there a way to make a "morph" preset (so it makes a dial when loaded under morphs), that I can distribute?
