where is GOZ app inside Daz 3d
meshcarvemeshcarve Posts: 0
Hi,
am a new user to 3D daz. recently i have installed DAZ 3D 4.5pro and also installed plugin for GOz app.
but am not able to find where is option or button to click GOz app inside the daz3D studio. help me. two times
and reinstalled the newly downloaded goz plugin in order to make sure
thank you
  • BlackFeather1973BlackFeather1973 Posts: 739
    In the Daz Studio menu : File -> Send to Zbrush
  • meshcarvemeshcarve Posts: 0
    no there is no such tab or option.
    Have you actually bought Z Brush? GoZ is only a bridge to that, you do need to also have ZBrush on your computer
    yes i have zbrush 4R5. but the option is not available with 4.5daz pro. what i should next. any way am going to uninstall 4.5 and install 4.6
    edited May 2013
    Works fine for me with Zbrush 4R5, have used it with DS 4.5.1.6 and 4.5.1.56.
    What versions of Studio and GoZ are you running ? 4.5.x.x, 32bit or 64 bit ?
    Edit to add : Win or Mac ?
    213 x 340 - 22K
    Post edited by BlackFeather1973 on
    In Zbrush under preferences -> GoZ, does it show an entry for Daz Studio ?
    882 x 508 - 23K
    edited May 2013
    finally it came dude....... but now new problem its while clicking the go to zbrush it is showing one message. "unable to connect with pixologic" what the heck is that. what to do now bro?
    Post edited by meshcarve on
  • Richard HaseltineRichard Haseltine Posts: 111,769
    As BlackFeather1973 asked, do you have an entry for DS in the ZBrush Preferences menu? Did you ever have a previous version of ZBrush, or the demo, installed to a different folder from the current version?
    I'm not sure, but i think you need to let Zbrush search for DazStudio again. Click 'Path to DazStudio' in the GoZ menu (see pic in my previous post), that should connect Zbrush to Daz Studio again.
    yes i have used previews versions of z brush, but those all are completely uninstalled. right now only zbrush4R5. yea to i did path to daz3d from zbrush. still it s showing unable to connect pixalogic..........
    please help me what is the next solution
    Sorry, meshcarve, i lost track of this thread.
    From what i could find in older posts, it looks like your Daz Studio is still trying to connect to a previous version of Zbrush.
    I'm not sure how to fix this, but i'd try to find the remnants of the previous zbrush installations and deleting those files, then uninstalling and reinstalling the GoZ.
    there is any way to delete manually any of some folders and fixing this problemm
  • JaderailJaderail Posts: 0
    Do a Unistall as suggested, then go to the OLD install folder and Delete any and All left over bits, Also delete any except your Work Saves if they are in a Folder of your own. Any thing except things YOU saved should go. On a Win7 PC look in the hidden AppData folder and remove anything for Zbrush found in it as well. Appdata can be found in C:Users/UserName/Appdata once Show hidden folders is set for folder views.
    I hope this gets you going. If not I'm out of info to offer.
    DONE.....ITS WORKING NOW.. I UNINSTALLED THE CURRENT ZBRUSH AND DELETED ALL FOLDER WHICH CONTAIN ZBRUSH INFORMATION. AND AFTER THAT REINSTALLED AND ..... REINSTALLED GOZ AGAIN... NOW ITS WORKING...... GUYS THANKS A LOT....
