IBLMaster
I am in the middle of doing a series of Iray renders. I decided to load IBLMaster to try and see what it is all about.
(I understand that it is likely that IBLMaster will give most impressive results when using 3Delight)
Anyway, I followed instructions, loaded IBLMaster, it seemed to load ok. The HDRI does not appear to load into the IBLMaster - the mini world globe does not appear at 0.0 - the HDRI appears otherwise as usual.
Loading the IBL lighting causes Iray to restart, as I would expect, but does not appear to affect the light levels in any way.
Are there more detailed instructions than the rather sketchy sheet to load/unload into the scene?
Seasonal good wishes to all.
The creator is answering technical questions in this thread: https://www.daz3d.com/forums/discussion/215066/ibl-master-image-based-lighting-control-for-both-renderers-a-new-ibl-for-3delight-commercial
Wow! God is there?
Thanks
