Error Loading Presets | Poses | .duf w/animation
bog10222bog10222 Posts: 0
After creating an animation w/DAZ Studio 4.5.1.56 Pro (32-bit) on WinXP Pro SP3 (32-bit) and saving as a .duf in Presets | Poses, attempting to open it in a later session, I'm getting the following errors. I'd prefer not to have to re-create the animation since it took a while to develop it, so any tips to determine what the problem is and resolve it would be greatly appreciated.
Thanks for any information you can provide.
UI error:
Error opening file
An error occurred while reading the file, see the log file for more details.
$HOMEPATH/Application Data/DAZ 3D/Studio4/log.txt extract:
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Link successful. The GLSL fragment shader will run in hardware.Shader Program successfully linked.
*** Scene Cleared ***
Error reading file, see log for more details.
DEBUG: End DAZ Studio to Hexagon Bridge log...
--------------- DAZ Studio 4.5.1.56 exited ------------------
    I just tried this on a Genesis figure. I created a simple animation, and I saved it as a Scene into my Scenes folder, and it opens correctly. I also saved it into my Poses folder, and it opened fine from there too.
    Did you save as a Scene or Scene Subset? If it was saved into a DS formats folder, it should be OK, no matter what sub-folder it was saved to I think. There are no errors given in the log file really, but what does confuse me slightly is the last part
    DEBUG: End DAZ Studio to Hexagon Bridge log…
  • Richard HaseltineRichard Haseltine Posts: 111,949
    Is that the DS log?
  • bog10222bog10222 Posts: 0
    The only related log file I could find was:
    If this is not the correct file, please let me know.
    I was able to get it to work by using the following steps:
    1. File | Open | Navigate to Scenes folder | Select scene which animation was based on
    2. File | Merge | Navigate to Presets/Poses folder | Select pose preset for the animation timeline
    UI reports the following dialog:
    Animation Range : Total Frames
    This preset contains information for frames beyond the length of your current timeline. Would you like to add frames to the timeline in order to import the entire file?
    I answered yes and the animation was successfully imported.
    I think what confused me was that it is a two-step process to load an animation, where I thought all I had to do was open the pose preset.
    If there is another way to do it, please let me know.
    Yes, that's the right log file - the contents just looked different so I wasn't sure.
    A pose preset should save animation, ready to be applied to the figure, but it doesn't save the figure itself.
    Well, I just upgraded to DAZ Studio 4.6.0.18 Pro (32-bit) on WinXP Pro SP3 (32-bit) and am now unable to merge the pose preset.
    I'm including an extract of the relevant section of the DAZ Studio log file, since I tried making it an attachment to this post as a .txt and .zip file, but I get the error: "The filetype you are attempting to upload is not allowed." and the content is too large for this post. I have omitted 117 additional WARNING messages of the following:
    WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis: .dsf
    Any tips or suggestions on how to resolve this would be greatly appreciated.
    +++++++++++++++ DAZ Studio 4.6.0.18 starting +++++++++++++++++
    Platform bits: 32
    Qt Version: 4.8.4
    Running on Windows XP, Build 2600, Service Pack 3
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Genuine Intel(R) CPU T2500 @ 2.00GHz
    Cache Line Size = 64
    L2 Associativity = 6
    Cache Size = 2048
    Stepping ID = 8
    Model = 14
    Family = 6
    CLFLUSH cache line size = 64
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 2.9 GB (3219501056)
    Avail: 2.2 GB (2385215488)
    Virtual Memory:
    Total: 1.9 GB (2147352576)
    Avail: 1.8 GB (1971798016)
    Current Memory Usage: 25%
    Current DateTime:
    Loc: Sat May 18 17:12:12 2013
    UTC: Sat May 18 21:12:12 2013
    Temp Data:
    Location = C:/Documents and Settings/Sergei Haramundanis/Application Data/DAZ 3D/Studio4/temp
    Disk Total: 59.5 GB (63913295872)
    Disk Avail: 28.6 GB (30779662336)
    Locale: en_US
    No translator found.
    Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Main Street.style
    Creating managers
    Reading help index
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.9.0
    Supported OpenGL extensions:
    GL_ARB_multitexture
    GL_EXT_texture_env_add
    GL_EXT_compiled_vertex_array
    GL_S3_s3tc
    GL_ARB_depth_texture
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_multisample
    GL_ARB_occlusion_query
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_shader_objects
    GL_ARB_shading_language_100
    GL_ARB_shadow
    GL_ARB_shadow_ambient
    GL_ARB_texture_border_clamp
    GL_ARB_texture_compression
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_rectangle
    GL_ARB_transpose_matrix
    GL_ARB_vertex_blend
    GL_ARB_vertex_buffer_object
    GL_ARB_pixel_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_window_pos
    GL_ARB_draw_buffers
    GL_ATI_draw_buffers
    GL_ATI_element_array
    GL_ATI_envmap_bumpmap
    GL_ATI_fragment_shader
    GL_ATI_map_object_buffer
    GL_ATI_separate_stencil
    GL_ATI_shader_texture_lod
    GL_ATI_texture_compression_3dc
    GL_ATI_texture_env_combine3
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_ATI_vertex_array_object
    GL_ATI_vertex_attrib_array_object
    GL_ATI_vertex_streams : NOT INITIALIZED
    GL_ATIX_texture_env_combine3
    GL_ATIX_texture_env_route
    GL_ATIX_vertex_shader_output_point_size
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_clip_volume_hint
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_object
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_pixels
    GL_EXT_point_parameters
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texgen_reflection : NOT INITIALIZED
    GL_EXT_texture3D
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_rectangle
    GL_EXT_vertex_array
    GL_EXT_vertex_shader
    GL_HP_occlusion_test
    GL_NV_blend_square
    GL_NV_occlusion_query
    GL_NV_texgen_reflection
    GL_SGI_color_matrix
    GL_SGIS_generate_mipmap
    GL_SGIS_multitexture : NOT INITIALIZED
    GL_SGIS_texture_border_clamp
    GL_SGIS_texture_edge_clamp
    GL_SGIS_texture_lod
    GL_SUN_multi_draw_arrays : NOT INITIALIZED
    GL_WIN_swap_hint
    WGL_EXT_extensions_string : NOT INITIALIZED
    WGL_EXT_swap_control : NOT INITIALIZED
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_ARB_pixel_format
    WGL_ARB_render_texture
    WGL_ATI_pixel_format_float
    WGL_ATI_render_texture_rectangle
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: ATI Technologies Inc.
    OpenGL renderer: ATI Mobility Radeon X1400 x86/SSE2
    OpenGL version: 2.0.6471
    Maximum number of lights: 8
    Number of auxiliary buffers: 0
    Number of texture units: 8
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 4096 x 4096
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 8
    GLSL version: 1.10
    Shadow mapping supported
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzassetiofilters.dll
    dzautofit.dll
    dzautoriggerbasic.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcontentdbeditor.dll
    dzcontentlibrarypane.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdelightrenderer.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzgoz.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzmorphloaderpro.dll
    dzobjexporter.dll
    dzoptitexclothbasic.dll
    dzpolygongroupeditortool.dll
    dzprimitives.dll
    dzpropertyeditor.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzrslshadercompiler.dll
    dzsavefilters.dll
    dzscriptedrenderer.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzsmartcontentpane.dll
    dzspotrendertool.dll
    dztextureatlas.dll
    dztransferutility.dll
    dzu3dexporter.dll
    dzweightmapbrush.dll
    dzwinvideo.dll
    sdk_sceneinfopane.dll
    dzmimicbasic.dll
    dzpowerpose.dll
    WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
    Total class factories: 1222
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    Executing startup script...
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSurprise.dsf#PHMSurprise?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/MCMV5Surprise.dsf
    File loaded in 0 min 13.3 sec.
    Loaded file: Synchopae_201304280939_Face_06.duf
    Loaded Morph Deltas in 0 min 0.0 sec.
    Loaded file: MCMV5TrapsVolume.dsf
    Loaded file: MCMV5ShouldersVolume.dsf
    Loaded file: MCMV5Nipples.dsf
    Loaded file: MCMV5EyeLidsTopUpR.dsf
    Loaded file: MCMV5EyeLidsTopUpL.dsf
    Loaded file: MCMV5BrowUpR.dsf
    Loaded file: MCMV5BrowUpL.dsf
    Loaded file: JCMV5rThighOut.dsf
    Loaded file: JCMV5rThighFwd.dsf
    Loaded file: JCMV5rShldrFwd.dsf
    Loaded file: JCMV5rShldrDwn.dsf
    Loaded file: JCMV5rShinBck.dsf
    Loaded file: JCMV5rHandUp.dsf
    Loaded file: JCMV5rFootDwn.dsf
    Loaded file: JCMV5lShldrDwn.dsf
    Loaded file: JCMV5lHandUp.dsf
    Loaded file: JCMV5lFootUp.dsf
    Loaded file: JCMlThighSideIn.dsf
    Loaded file: PBMAreolaePerk.dsf
    Loaded file: PBMAreolaeDiameter.dsf
    Loaded file: PBMAreolaeDepth.dsf
    Loaded file: PHMMouthNarrowR.dsf
    Loaded file: PHMMouthNarrowL.dsf
    Loaded file: PHMMouthCornerUpDown.dsf
    Loaded file: PHMLipTopUpR.dsf
    Loaded file: PHMEyeLidsTopUpR.dsf
    Loaded file: PHMEyeLidsTopUpL.dsf
    Loaded file: PHMEyeLidsTopDownR.dsf
    Loaded file: PHMEyeLidsTopDownL.dsf
    Loaded file: PHMEyeLidsBottomUpR.dsf
    Loaded file: PHMEyeLidsBottomUpL.dsf
    Loaded file: PHMCheekFlexR.dsf
    Loaded file: PHMCheekFlexL.dsf
    Loaded file: PHMCheekEyeFlexR.dsf
    Loaded file: PHMCheekEyeFlexL.dsf
    Loaded file: PHMBrowUpR.dsf
    Loaded file: PHMBrowUpL.dsf
    Loaded file: PBMNipplesVolume.dsf
    Loaded file: PBMNipplesDiameter.dsf
    Loaded file: PBMNipplesDepth.dsf
    Loaded file: PBMNipples.dsf
    Loaded file: PBMLoveHandles.dsf
    Loaded file: FBMVoluptuous.dsf
    Loaded file: PBMWaistWidth.dsf
    Loaded file: PBMRibcageVolume.dsf
    Loaded file: PBMV5BreastShape8.dsf
    Loaded file: PBMV5BreastShape1.dsf
    Loaded file: PBMUpperArmsVolume.dsf
    Loaded file: PBMTrapsVolume.dsf
    Loaded file: PBMThighsVolume.dsf
    Loaded file: PBMShouldersVolume.dsf
    Loaded file: PBMShinsVolume.dsf
    Loaded file: PBMNeckSize.dsf
    Loaded file: PBMKneeBonesVolume.dsf
    Loaded file: PBMHipVolume.dsf
    Loaded file: PBMHipBoneVolume.dsf
    Loaded file: PBMGlutesVolume.dsf
    Loaded file: PBMForearmsVolume.dsf
    Loaded file: FaceRound.dsf
    Loaded Morph Deltas in 0 min 0.1 sec.
    Loaded file: FaceAnimal2.dsf
    Loaded file: FaceAnimal1.dsf
    Loaded file: EyesShape3.dsf
    Loaded file: Cheekbones.dsf
    Loaded file: UpperLashLength2.dsf
    Loaded file: UpperLashLength1.dsf
    Loaded file: NoseTipVeryFlat.dsf
    Loaded file: NoseShapeRound.dsf
    Loaded file: NarrowNostrils2.dsf
    Loaded file: LargerLips.dsf
    Loaded file: EyeOpenShape2.dsf
    Loaded file: ArchBrowR.dsf
    Loaded file: ArchBrowL.dsf
    Loaded file: AdjUnderNose.dsf
    Loaded file: SquareNoseRidge.dsf
    Loaded file: PhiltrumWidth.dsf
    Loaded file: NoseNarrowLong.dsf
    Loaded file: NoseCenterBroad.dsf
    Loaded file: NarrowMouthChin.dsf
    Loaded file: MouthCornersUp.dsf
    Loaded file: MouthAreaOut_head.dsf
    Loaded file: GoodCheekbones.dsf
    Loaded file: EyesTogether.dsf
    Loaded file: BrowDown.dsf
    Loaded file: FBMVictoria5Sprmdl.dsf
    Loaded file: FBMVictoria5.dsf
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiLimbs.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiLashesMas.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiLashes.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiLimbsS.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiEyeTran.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_CornReflec.JPG
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiLimbsB.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiEye1.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiEye2.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiTorso.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiMouth.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiTorsoS.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiTorsoB.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiFace.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiFaceS.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiFace_B.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/SC_Spec.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/SC_Tex01.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_LacTran.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/SC_Trans.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/SC_Bump.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/LF_Tex01.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Morris/V5/Gabi/JM_GabiFaceMU7.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/LF_Spec.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/LF_Bump.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/LF_Trans.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/TM_Tex01.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/TM_Spec.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/TM_Trans.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/TM_Bump.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/BF_Tex01.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/BF_Spec.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/BF_Bump.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/BF_Trans.jpg
    Ran tdlmake on image C:/Documents and Settings/All Users/Documents/My DAZ 3D Library/Runtime/Textures/Michelle/WildcatHair/HL_Tex01.jpg
    --------------- DAZ Studio 4.6.0.18 exited ------------------
    Ok, I solved this again myself by rebooting Windows XP and starting another DAZ Studio 4.6 Pro session.
    There must have been some residual DAZ Studio 4.5 Pro references remaining after the upgrade which were causing the problem and were cleared after the reboot.
    For those upgrading to DAZ Studio 4.6 Pro, to avoid this problem, make sure you reboot your operating system before starting a working session.
