Can't apply shaders
When I try to apply a shader, I get this message, "An error occurred when reading the file, see the log file for more details." Problem is, when I attempt to open the log file, notebook opens but nothing appears on the page, just the twirling busy circle, and the log file never opens. What can I do? Can this be fixed?
  • barbultbarbult Posts: 27,455
     Maybe your log ifile s too big for notepad????
    Hold down the Ctrl key when you click on the menu command for opening the log file. That will open a Window showing you the folder that the log file is in. Locat the log file in that folder and open it with another application that can read text files.
  • LindaBLindaB Posts: 193
    Thank you. I was able to open the log file thanks to your instructions. A huge file, endlessly long, here's what it said on top:
    Successfully created OpenGL viewport for AuxViewportView.
    WARNING: QFile::flush: No file engine. Is IODevice open?
    WARNING: QLayout: Cannot add null widget to QGridLayout/
    Executing startup script...
    Started in: C:/Program Files/DAZ 3D/DAZStudio4
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Shader Program successfully linked.
    I don't know what to make of this, should I send a support ticket?
  • Did you have the item and surfaces on the item you wanted to apply the shader to selected? Shader presets need both.
    I had the item selected, but not the surface. When I selected the surface, it worked no problem. I've been using DS for a few years now and never ran into that problem before. Thanks for the solution.
