sending to studio
Ruphuss
sending to studio does not include textures ?
have newest versions
Ruphuss
sending to studio does not support groups ?
sending to studio a form loses its ability to get dforce surface simulation settings ?
if a form is thickened it cannot be used for dforce ?
1. Textures - I can send textures.
2. Does support groups, but if you have a group inside a group can cause problems (material name gets messed up).
3. Not sure. I think you want to export/import it as an OBJ - That way you can use the Transfer Utility thingy (I don't make clothes very often).
4. Thickness, only tried it with a rug and tablecloth and it seemed to work okay - You may want to check your collision detection.
You will get better info on dForce in the DAZ Studio discusion forum.
2.i only get morphs in studio as an offer
3. yes obj no problem
4.it does not get dforce surface simulation settings in studio
About the Hex-DAZ studio bridge, it will not work with Iray materials, it's 3Delight only.
I'm not into dForce at the moment, I've played a little bit but that's about it.
