Wet Geometry Shell dose not apply nipple replacement (dForce HD Wet and Dry Baby Doll Dress)
I am using Wet Geometry Shell which include dForce HD Wet and Dry Baby Doll Dress.
But, It does not apply on Nipple Replacement Items.
I tried somethings but not gonna work.
And I research a lot about that.
I can not resolve this problem.
Plase help me.
Thank you for reading.
Bux.
Mod Edit ;- Image removed due to Nudity.
1226 x 2520 - 614K
1234 x 2574 - 504K
Post edited by Chohole on
That image is going to get removed for nudity.
I would suggest going to Renderotica and asking Meipe about it. However, I suspect that since those already use a geometry shell to blend into the skin, trying to use a geometry shell effect will not work.
You would also need to check that the material names matched, if they have unique names the shell wouldn't hae settings for them (though in that case you could copy-and-paste the surfaces settings after applying the base shader).
Thanks!
I asked to Meipe on renderotica and it was solved.
Save the Shader presets which is Wet GeoShell torso surface.
And then load the shader presets on geo shell both headlights surface.
Thanks a lot.
You always help me on the forum.
Thanks every time :)
