[solved] setsuka morph help.
artxtapartxtap Posts: 186
edited December 2017 in Daz Studio Discussion
have setsuka by vrxitachi on win xp 32bit works. new machine with win 7 64bit can not get the setsuka g2f morph to work. any ideas?
WARNING: dzneuraymgr.cpp(403): Could not add path: "C:/Users/...path to .../DAZ 3D/Studio4/shaders/iray". Due to unkown error -2
WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(CUDA:RENDER):   0.0   CUDA   rend warn : CUDA module initialization failed.
WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(CUDA:RENDER):   0.0   CUDA   rend warn : The version of your CUDA driver is 0.0, but 8.0 is the required minimum
Body R.duf is setsuka morph.
Loaded file: Body R.duf
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadSS.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadM.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeHeadTL.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeEyesB.jpg
Ran tdlmake on image C:/Users/Public/Documents/My DAZ 3D Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeEyesM.jpg
tdlmake does not load the morph.
edit: my mistake there were more files at another location. solved
files are every where :-)
Post edited by artxtap on
  • tdlmake is not connected to morphs - it is a utility that takes an imaeg file (for a texture) and converts it into a special kind of image file for 3Delight, which is the actual file used in the render. Ther other messages relate to Iray, it seems to be having trouble initialising (which is probably why you are in 3Delight, if it wasn't by your own choice). Are you getting any messages from DS when you load the file?
