Posing Genesis 8 & Victoria 8
I see packages that contain different sets of poses for Genesis 8 & Victoria 8. I had thought that they would be the same. What are the body differences that cause the need for separate posing versions?
The shapes differ (that is, in part, the point of Victoria 8) so a pose that has the hands on the hips for one may hae the hands buried inside the hips or floating in mid air for the other, and so on. Poses that don't involve contact, or near contact, between body parts may be usable on either shape but others will need to be adapted.
Will it usually just be minor adjustments like I have to make when I morph a G8 Character or use a 3rd party Character? I already end up having to adjust hand on hip poses and others like that because I use a lot of 3rd party characters and morphs.
Look at the poses in the promo images for each figure's pose add-on. If they're kinda the same pose, then yes, it should just be minor tweaking to get the same results. You may run across one or two where the joint rotations for the wrists or fingers seems to be skewed, but for the most part, poses for one should work on the other with only minor tweaking needed.
Thanks for the info!
