Converting clothing G1 to G3. How?
I thought I found a forum discussing this. It was referred to by a link but clicking it just loads my account page so I have to assume it was moved or deleted. Guess I'll ask again.
I searched high and low to find scout uniforms and finally found one for Genesis male. Problem is it does not work well at all on G3 so hit a road block. (I could not find for G3 M or F although I did make a "passable" modification to a texture, it lacks the neck bandana etc. )
Is there a way to convert older clothing items to G3? plugin or other tool would be good even.
Thanks.
Fit the item to Genesis 2 Male, you will get the AutoFit dialogue in which you shoudl set Genesis as the Source figure and you may want to test the clothing type options (but you don't have to). That will adjust the shape and rigging to work with Genesis 2 Male. Now fit the item to Genesis 3 Male, you will again get the AutoFit dialogue in which you this time set the source figure to Genesis 2 Male. There are products in the store that will let you go straight from Genesis to Genesis 3 Male, which skips one step, but this route works (within limits) and is free.
Thanks I'm going to try that trick.
How do I save the first adaptation (G1>G2) to then transfer to G3? Do I save the clothing items as assets?
Also what is the product that does that? I may still like to have it.
Have a great holiday !
Wear Them All - Autofitting Clones and Clothing Smoothers for Genesis 3 Female(s)
Wear Them All - Autofitting Clones and Clothing Smoothers for Genesis 3 Male(s)
They work well.
I'm not sure you have to save the intermediate item, though I would - File>Save as>Support Assets>Figure Asset, I would put your name for Author but then put soemthing like AutoFits for product (as a reminder that it isn't all your own work). You can do the same with the final item.
