Is there a preview window available in DAZ Studio 4.5 that allows you to easily see changes in light
galactica1981galactica1981 Posts: 1,251
I'm taking the Light Master course from Dreamwave. Some of the tutorials are done using Lightwave and that software has a nice preview window available. Does DAZ Studio have something similar?
  • SzarkSzark Posts: 10,634
    Simple answer is no sorry.
  • Richard HaseltineRichard Haseltine Posts: 111,625
    What you can do iss et up a low-quality render preset (high shading rate, low ray trace bounces and samples and progressive rendering, though if you use that always cancel rather than letting it plod on to completeion) with a reduced size render and use that to generate relatively quick previews, then have a higher quality preset for your final renders. File>Save as>Render preset. Also remember the spot render tool to check local areas without having to check everything.
  • linvanchenelinvanchene Posts: 1,386
    edited November 2013
    edited and removed by user
    Post edited by linvanchene on
