Dforce Keeps Messing Up
Richard John S
I have gotten it to work once with the same settings, same clothes, same character, etc... This is what happens after the one time I got it to work which took a few tries. I am using the new wet and dry baby doll outfit which is Dforce ready.
https://www.daz3d.com/dforce-hd-wet-and-dry-baby-doll-outfit-for-genesis-8-female-s
842 x 851 - 821K
Post edited by Richard John S on
Make sure no part of the item is pinched between two parts of the body, like the arm and torso.
The latest version of dForce has a function to show initial collisions. Use that and see if there's anything you may need to adjust before running a sim.
Also, I know you said the same settings as before, but those settings may be interpreted differently than the previous version. Either re-set them manually, or play around with them to find the new "good".
Also set your Colision Layers separately. Closest to the skin is Collision Layer 1. Everything above that is 2 and up.
Thanks I'll give that a try. I think the arms were actually poking inside the clothing.
