Winter HDRIs - Nothing Showing Up?
Xenomorphine
in The Commons
Daz Studio is recognising the product, but after installing, nothing is showing up after exploring it in the Smart Pane. I've uninstalled/reinstalled it and restarted Daz Studio, just to be on the safe side, but the HDRI stuff isn't showing up inside it.
Is anyone else experiencing this?
Where are you looking? HDRI's are usually found under render settings. You can also look for it in the regular content pane alphabetically and assuming it's there, right click and then click on "show in smart content." That's how I found my HDRI's in the smart content pane and they were under Render Settings. But I don't have the winter ones... yet...
@Xenomorphine , you should find them in Content Library->Environments->AMLM->Winter HDRI. They are organized in two folders, LR and HR (respectively Lower and Higher Resolution); each one comes with a Render Settings Preset and Camera Preset.
See, I would not have thought of looking under Environments. All my other HDRIs are found in Light Presets folder. Is this actually an environment that loads into your scene or is it a lighting environment that does not actually load onto the scene unless you render it or preview under Iray? It makes it difficult for users to figure out what folder to look into when PAs veer from the usual.
The product shows up in the Smart Content panel, but it has no contents. I right-clicked on it and selected 'Show Product In Content Library' and there are no visible files in that, either (which lists it under the 'Products' A-Z section).
I didn't mess around with doing anything manually. I allowed Daz Connect to automate the installation, as with all my purchases. It did install something as it went through 'INSTALLING 1 OF 9', etcetera, which I assume equate to nine different HDRI image files. Yet, following this, nothing actually shows up within the product, even after restarting DS a few times.
Bit of a puzzler, this!
Hi guys i am the co-PA of the product with Alessandro. I have downloaded the package from the Install Manager and works perfectly. This shows in the Content Library->Environments->AMLM->Winter HDRI as AM has written. I think that is the right location because is not only a light setup but a total HDR environment. You must load the camera object and the render setting for the right setup. Thank you guys and hope this helps. Luca
Hope that the two attached screen-shots help.
One demonstrates no contents showing up in the Smart Content panel when the product is selected, along with no AMLM sub-folder in the Categories -> Environments section. The other shows no contents showing up when selecting it directly through the Products -> A-Z section.
I'm not sure if can be a Connect related issue. Can you try using the Install Manager?
Using DIM, it does load under environment folder just as Alessandro mentioned in his earlier post.
It's showing up in Smart Content, now that I've used DIM to install it, instead. Thanks. :)
The store page says it's compatible with Daz Connect. Unless it's updated to do so, you guys might need to corrrect that information on there.
