DS 4.10 uninstall/re-install problems
rabbitsfoot_jay_8f88a89192
I had to do a clean uninstall/re-install for DS 4.10 and I have been running into some problems.
I don't know whether or not I've installed Genesis into DS, for I get error messages saying that it isn't there.
I've been running DIM and installed through DIM, no change at all.
Also, I don't see a My Libray under X:\Xxx\Documents\DAZ 3D\Studio, just the My Daz Connect Library.
It's been quite frustrating. Can someone help me with this?
Thanks
Jay
I was having the same problem. Just fixed it. Assuming you are on a PC, not an Apple:
I added postgresql CMS from the Daz Install manager{DIM}.
I opened Daz Studio.
At the bottom of the Content Pane, there was a bright blue button to conect to the CMS. I clicked it.
Still none of the content I just installed, So I used the DIM to uninstall and then reinstall it.
Content is there now.
Hope this helps you.
See also:
https://helpdaz.zendesk.com/hc/en-us/articles/207812393-PostgreSQL-Connection-Error-and-No-Smart-Content
Thanks dweomer for your help.
Yes, I am running on a PC, and I followed the steps you gave me about the postgresql CMS from DazDIM.
I tried the DIM thing and it managed to install some of the Genesis content I wanted, but in my MyDaz3dLibrary folder, not the My Library one on the Daz Folder in Documents. So, I donno, it maybe that I'm using a newer version of DazStudio 4.10, but I did managed to get Genesis 2 and 3 figures to work, I've yet to get G8, I may have to uninstall/re-install.
Attached is some screen shots.
Many thanks,
Jay
You can override/change the default install directory with the DIM, though I haven't used that recently.
I've run into problems doing that because some older content still has some path dependencies.
I see. Thanks!
Happy Holidays,
Jay
