How do I get the hair to show properly?
in New Users
This is a genesis character with genesis hair - catwalk hair and andrea character - I played with it a little but not much. How do I get the hair to fall over the hoodie, or under it, either one would be fine. Right now it falls in the hoodie and out of it,
337 x 378 - 23K
Have you tried using the movement morphs that come with the hair? They should be in the Parameter tab under "Actor" when you select the hair.
Yay! that's got it! Thank you! Bee. I used fixes but same difference.
The fixes are usually meant to help fitting problem due to different head shapes.
Thanks Dee
