Question on: Genesis 8 Female MEGA Wardrobe
nicsttnicstt Posts: 11,715
edited December 2017 in The Commons
https://www.daz3d.com/genesis-8-female-mega-wardrobe
Are the different Jeans modelled, or do the lengths depend upon textures?
I could buy an return, but if I know that they are wholly texture-dependant then I don't need to bother.
Post edited by nicstt on
  • HavosHavos Posts: 5,703
    The lengths are adjusted via the material settings, however, the turned up sections at the bottom of the cut down jeans are modelled. These sections are set to invisible when the untextured jeans are loaded, and then are made visible depended on the length of jeans selected. They look fine IMHO, but on close inspection I think they are not attached to the main mesh. As such if you wanted to use this in something like dForce, then the bottom loops would fall off without some additional work to meld it to the main mesh.
    I can post some images if you need any extra help.
  • SimonJMSimonJM Posts: 6,100
    The lengths are dealt with via transparency - sections not seen set to 0% Opacity.
  • nicsttnicstt Posts: 11,715
    Thank you both; guess I'll pass.
