Can't register? 404 page.
When I try to register the software, it sends me to the following page...
https://www.daz3d.com/i.x/support/registration/-/?
which comes up as a 404, page not found.  Any thoughts?
    edited December 2017
    as far as I know you don't have to register it online,
    you doing this ??
    Step 4 - Register Carrara 8.5
    • The first time Carrara 8.5 is launched it will request a serial number.
    • Your Carrara 8.5 serial code can be found in the 'My Account' section under 'My Serial Numbers'
    • Carrara 8.5 will not accept Carrara 8.0 or 8.1 serial numbers.
    • Carrara 8.5 will not accept outdated Carrara 8.5 beta serial numbers.
    • The 64 bit version of Carrara 8.5 must be registered with a pro serial code.
    Post edited by Headwax on
    you doing this ??
    No, its later, after that point.  It gives a link to 'register online'.  It's purely optional but its in an extra step...  almost like you expect a EULA to be there.
  • DartanbeckDartanbeck Posts: 22,159
    thomask_1 said:
    you doing this ??
    We can ignore that. We're each already registered upon purchase at Daz3d. It used to do something but since then the page has disappeared from the webway. They should just make a little page at that address that says "Thanks for Buying Carrara" or "Thanks for Shopping at Daz3d" or something! ;)
    404, page not found is so boring!
  • I Agree!  Thanks!
