Gray Work Space
The work area (or whatever you call it) used to be blue with a bunch of square lines.
But now after adding and deleting a prop, the work area is all gray and has only two lines.
Can someone tell me how to get it back the the blue with all the squares?
Thanks in advanced for your help !
  • Do you still have the Viewport tab at the top? If not it may be that you have closed the viewport, you can reopen it from Window>Panes(Tabs)>Viewport and then drag by the top bar to the top of the grey area, releasing when you see a line of highlight colour to dock it. If you do still have the Viewport tab please post a screenshot.
  • Kelly Lodge1 is the one that I added to the scene and then deleted it.
    And then everything is gray.
    1891 x 847 - 156K
  • Richard HaseltineRichard Haseltine Posts: 111,937
    edited December 2017
    Ah, it's just changed the backdrop colour to mide grey, which hides the grid - since it affects only the aspect frame that would be via Window>Panes(Tabs)>Environment, I think, but there's also the (non-rendering) Viewport background colour in Window>Style>Customise
  • Thanks ! Looks good now.
