Render Time-Look At My Hair
Vitachick
Have Win XP32 bit (which I normally use) and Win7 upgrade from XP32..
I have above in my cart. What is the d/l time and will comp crash?
Suggestions....Love the results I have seen....
We test in XP32 all of the time. It'll work just fine. On 32 bit environments you need to be a bit more conservative on the number of hairs used, but you can easily get RawArt's Sasquatch loaded in there as well as any of the free presets at http://www.furrythings.com
EDIT: the archive is much smaller than most models, about 10M or so
EDIT2: If you have problems, contact us and we'll be glad to help.
Kendall
What extactly are you asking? Will it render using a 32 bit system? Then I would say yes but it all depends on how much you have in the scene and how much Ram you have. Renderman Curves which is how LAMH makes hair doesn't take as much memeory as actual geometery.
Downloads time...lol well that depends on your interenet service provider, only you can answer that one.
Looks good for me.....Will get out of my cart and purchase...
Glad to see their is support.....Also have Win7 64 bit on other comp...
Thanks for reply!!!!
OK/ Purchased..Now how do I get it to open???? Have sent email to
[email protected]
Do not get window asking for serial number etc...
What OS are you using? Did the installer complete without errors?
To start LAMH 1.0, use the Create Menu, then select "New 'Look At My Hair' Object...
The first time you run you will be presented with an activation screen. Enter your DAZ supplied SN on the 2nd line. Then go to the website listed. Enter the info from the 1st 2 lines into the lines on the web page. You will then be given an activation code. Copy/Paste this code into the 3rd line and click on 'ACTIVATE'
Kendall
Well when I do that, a window opens looking for (*lmh)..????
Trying to install on My Win XP 32 bit comp...Haven't tried
yet on my Win7 64 bit
That sounds like you're using the player, not the full plugin.
Kendall
Purchased yesterday and this is what is listed in available d/l for Win XP 32 bit
Download
9.15 MB
15548_DS4_LAMH_1.0.0.0_Win32.exe
When I try to reinstall, it says already installed, and will uninstall to
prevent conflict....
??????? Installer error maybe?? Have no clue...
Contact me via email: krsears (at) trdc.biz
Kendall
