I am new to Bryce
tonyma40tonyma40 Posts: 0
Still continuously having problems installing software content from the store. I just purchase the The Deep Space Cruiser, DSC-001 for Bryce. I open Bryce and cannot find the content..I looked in the create menu and cannot find it.How can I get this software into Bryce?
    I don't have that one but have lots of other OBP files.
    The experts are over in the Bryce forum.
    How I find stuff in Bryce is by installing everything to a collector folder, then moving the various files into folder with similar files.
    Bryce > Presets > Objects > Installer > in here I put the .obp files.
    Then in Bryce 7, from the tiny arrow at Create, from the popup window under 'installed' is everything I put in that folder.
    875 x 601 - 171K
  • Scott LivingstonScott Livingston Posts: 4,352
    If it's not showing up in the Object Library, perhaps it wasn't installed in the correct location...I'm still relatively new to Bryce myself, but here are a couple of links that may help:
    http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf
    https://helpdaz.zendesk.com/entries/124773-Importing-Bryce-Object-Presets-obp-
    edited May 2013
    This is quite an old product. I personally would run the installer to a temporary folder on your HD to unpack it, and then import it (using the import button at the bottom of the object presets library screen that Patience shows in her screen shot), rather than letting the installer put it where it thinks is correct.
    THe installer was probably made when XP was the current windoze version (maybe even earlier than that)., and we all know the newer versions of windoze (ie Win 7 and Win 8) are a bit particular as to where stuff lands.
    Post edited by Chohole on
  • tonyma40tonyma40 Posts: 0
    Thank you all for your suggestion and it helped. What I did was installed the software into a desktop folder and Imported it using the object menu and saved is the miscellaneous menu and it worked. Thank you very much for you help.
