Zero Pose
Is there a zero pose function in Daz Studio 4.x?
  • AllenArtAllenArt Posts: 7,176
    Yes, select the figure in the scene tab, to go Edit/Figure/Zero...inside there will be a few options to zero your figure like pose only, the shape, etc.
    Laurie
    Laurie
    If you are not seeing that after an update to D/S you may need to go to window > workspace > update and merge menus
  • FSMCDesignsFSMCDesigns Posts: 12,859
    edited December 2017
    Laurie
    Amazing how how many ways there are to do the same things in DS, it's like multiple people programmed it while not checking with each other, LOL.. Can also go to the parameters tab and click the little icon in the top right for options
    804 x 579 - 285K
    Post edited by FSMCDesigns on
    Laurie
    Having multiple ways to reach the same command is not a fault, it allows for flexibility of workflow as it is possible toa void long movements to get from one UI area to another.
