frustrated about monthly discount coupons
shanteshante Posts: 206
I am getting really frustrated with the DAZ monthly discount coupons not working.
I check all purchases and it seems the ones I always pick to work for me to buy and use are non-DAZ products, which by default do use the coupon.
I was trying to apply the coupon code this month with products which are clearly marked as DAZ products and I keep getting the error message that the coupon does not apply. I see no darn point getting offered a courtesy coupon for being a long faithful customer if I can never use it. I have not been able to use for the past several months. I have also found the more expensive DAZ products are getting more and more for D/S use which is also frustrating for older Poser version users who can't afford Poser 9 or above or just don't want to install albeit the free version of D/S to make use of the DSON Exporter/Importer DAZ generously offers free.
Products referring to are:
Wind Dancer
DAZ 3D
Bobbie25
Sarsa
Muelsfell Display Plinth (which I think may have been a freebie I stupidly missed for being unable to fix my WiFi problem)
DAZ 3D
E-Arkham
You would think the coupon would cover the purchase of the two items in an overall purchase of over $75.00 but it doesn't
What is the point I ask.
I know DAZ is a business and inderstand its primary directive, but I guess I am feeling a bit frustrated.
  • R25SR25S Posts: 595
    I think the coupon should work on these items...
    I bought the Magic Containers (DAZ 3D, Lyrra Madril) and the Wizard Study Furniture (DAZ 3D, Lyrra Madril, IceWolfX) a few minutes ago and the coupon worked.
  • Richard HaseltineRichard Haseltine Posts: 111,475
    Are you sure you are entering the code correctly, and in the correct box?
  • LindseyLindsey Posts: 2,017
    You can only have DAZ3D products in your cart when applying the $6 monthly PC coupon. IF there is a PA product in the cart, the coupon won't work.
  • frank0314frank0314 Posts: 15,109
    Sometimes it will sometimes it won't. I've had it work and not work with a AP product in the cart. But, I generally only put DAZ O's in the cart when using the coupon to avoid the issue. I do occasionally forget and the coupon will or won't work. If it doesn't I remove the PA product and check out separately with that.
  • mrposermrposer Posts: 1,137
    You would be better off breaking the $75 order down to 3 $25 orders if possible to get the $5 off each order promotion.
  • shanteshante Posts: 206
    What promotion?
    The coupon is good for only $6.00 monthly purchase. Is there another promotion going on for other items and how do I find out what those items might be?
    I am pretty sure I am...the irst empty box at check out...right?
  • anikadanikad Posts: 1,919
    shante said:
    What promotion?
    There is a general $5 off $25 going on, details are here: http://www.daz3d.com/sales-promotions/
    Yes. You were using the 05 version of the code, assuming it was since the turn of the month? If it stubbornly isn't working, please open a support ticket.
    OK Got it to play nice.
    I took some of the more expensive non DAZ items off an ran it through and got the discounts including the coupon and $5 off discount.
    Thanks all for the advise. Now if only I can remember.
  • DkgooseDkgoose Posts: 1,451
    Wait, the $5 off $25 or more is valid more than 1 purchase, I figured it was a one time use
  • robkelkrobkelk Posts: 3,259
    edited May 2013
    And I thought it was just for May 5...Go figure.
    Edit: And the coupon in the "Exclusive Coupon - Stacks with Cinco de Mayo $5 Off" email that some people got applies on the price before the $5 discount, not after. Sixteen Platinum Club items plus the weekly freebie for $20.84 - I'm finally figuring out how the system's set up now.
    Post edited by robkelk on
    Glad you're figuring it out I still think it is way more complicated than needs to be. Too many things to read and weed through and too many tricky options to read around for my tastes. I have been a PC member for a long time here and a customer at DAZ long before it was DAZ and these complex and multi-layered discounts and sales and bonuses are getting taxing for my gray matter to wrap itself around.
