Animate2 .MDD to C4D - object disappears
Hey Guys, i have a problem with the import of .mdd data into cinema4d. Tried to load the .mdd file on a .obj also exported from Daz.
My C4D R17 dont support the mdd import so i got me Riptide Pro plugin. But everytime when i select the .obj and import the mdd the model just disapears.
Anyone have a workaround for that problem?
warm bytes.
  • Is it a scaling issue? Has the OBJ been grossly enlarged or shrunk, so it no longer appears in view?
  • wolf359wolf359 Posts: 3,955
    edited December 2017
    Hi
    As Richard stated, this is likely a scaling issue
    Riptide pro should have some import scaling presets.
    If you are using  Daz  Genesis figure Export the .obj
    From DS using the Poser scale preset
    over in C4D us the riptide .obj importer of course NOT the rubbish
    C4D obj import and choose the poser scale preset
    In the MDD deformer I have found a Scale of about 450 works for me
    But you may have to experiment based the scale you have chosen in C4D
     for props and other scene geometry.
    378 x 599 - 43K
    469 x 588 - 91K
    Post edited by wolf359 on
