Why does DAZ Studio render in a smaller box?
I probably hit the wrong key with my fumble fingers. When I do a render, it always comes in a smaller box. I tried increasing the size of that box, but it still renders in a smaller size. Help?!
1024 x 578 - 357K
  • DaWaterRatDaWaterRat Posts: 2,887
    On the Render settings tab, you can designatte the size of the render, including rendering to a file rather than a new window if you like.
  • Gusf1Gusf1 Posts: 258
        I believe the render size is determined by the Render Dimensions in the Render Menu.  The viewport is determined by your dragging it out.
                          Gus
  • Ron KnightsRon Knights Posts: 2,795
    edited December 2017
    OK, I think I found it. I needed to select Active Viewport in Dimension Preset. I couldn't get a screenshot because the Render Settings window disappears when I try.
    Post edited by Ron Knights on
    I just went to 'render settings', Clicked on 'general', and there it was.  The aspect ratio was 10:13 and the pixel size was 1000 x 1300.  The boxes make it look like you can change them if you like.  Your aspect ratio also shows at the top of the render frame in the viewport.
                        Gus
    Thanks, I got it. There must be some sort of hotkeys to change render settings. I must have hit the hotkeys when I was fumbling about.
