Saving LIE Presets
How do you save an LIE preset? For example, if you've added a skin tattoo layer to a couple of channels in your skin shader (like Base and Translucency), and you've placed the tattoo layer in the right spot, and want to save JUST the tattoo settings as a preset so you can use it with other characters with different skins, and apply the layer to both channels, what's the magic formula?
Thanks.
  • DigiDotzDigiDotz Posts: 515
      File>Save As>Layered Image(s) Preset. Expand properties and select what you want saved ..i think so
  • BeeMKayBeeMKay Posts: 7,019
    There are two options. First, you can use a plugin to bake the textures
    Or, you'll go to your DS TEMP folder, and find the combined map that DS creates from the LIE settings, and copy that to a different location (probably rename it, too). You can then manually replace the LIE map with this map, and save the entire thing as a material preset, for example.
    Wow, excellent. That worked great.
    Thanks much
